'04 1sr gear only, lights on dash
Just purchased my first Crossfire. I absolutely love the looks of the car. It is a 31K, one fussy owner car. It is in mint shape But it has the same problems that some of you have had and I am looking for a best guess solution. As an automatic, it will not shift out of 1st. It lurches hard going from P to D or R. The tire monitor on the dash is lit along w the check engine, the ABS, the parking brake, the BAS ESP and the wing is up and wont retrack. the scn tool also indicated 3 of the 4 With my Mac Mentor I pull up PO600 and PO720 and 2310 controller area network comm w traction system malfunction. Those that I think I clear come back as soon as I try to start. The last I read of guys with the exact same problems indicated they thought the ABS controller was bad. Any new ideas? Are there companies that restore these ABC units? The previous owner also said his scan tool picked up that 3 of the 4 wheel speed sensors , 1140 steering angle, 1141 electronic stability brake press and that trans pressure in park was 7 lbs, in drive it jumped to 112. . I am looking for suggestions.
Thank you
