Old Jul 26, 2019 | 09:40 AM
KDW4Him's Avatar
KDW4Him
Default Re: '04 1sr gear only, lights on dash
Originally Posted by Bigtoyz
This car is like new, never driven on gravel, stored in a heated garage, covered, and even padded during storage. The ist owner replaced the battery when it happened last fall wo change but I plan to check or replace the battery and battery cables tomorrow morning for myself. He also had the fuse/relay panel replaced with the updated soldered version thinking that was giving him problems, no change.
I am a high school auto instructor so a dealership is the last place this car will be going to. Your stuck w me. The best help comes from the DIY ers. Im working on finding a good schematic now and just thought those who have been there, done that could get me going in the right direction. Thanks
Could this be the car that had the battery connected backwards? Seems that owner spent a ton of time but don't recall it ever getting fixed.
CAN bus has an easy check, find any module with it and measure the resistance between the pins. Battery disconnected of course. 60 ohms will have continuity to both terminating resistors. Anything else you will have to find the wiring or module with terminating resistor problem. If I recall correctly the SKREEM module had one of the 120 ohm resistors.
