Old Aug 6, 2019 | 06:24 PM
Space coupe's Avatar
Space coupe
Default Re: Speedometer not working, spoiler up, ESP/BAS and other warning lights on
I cannot see any posts that mention error codes. Seems to me that is the first place to start.
When I plugged up my car it read p0600 on several different readers and dealers which is a broad code relating to bus communication errors and what could potentially be the issue. One mechanic told me it was my abs module and I replaced it and that didn’t do anything. I’ve swapped my RCM (several times) that also didn’t work. Through my testing so far everything points to can +b/-c bus and it just connects all the cars modules together via wire splices to two 20 awg wire. If this is the problem I’m going to use 18awg to replace it and use different wire nuts and wire it through the inside of the cabin under the dash.
