Old Aug 12, 2019 | 10:58 PM
Speedy4x4's Avatar
Speedy4x4
Default Re: Procedure for replacing flex joint?
Yes they can be changed by themselves with relative ease.
How many miles are on your crossfire ?
Before you order I would check the play in the bearing.
The u joint in the middle of the 2 piece shaft is non rebuildable.
Some change the flex discs and bearing and have to keep the joint, some just get a whole new shaft.
The bearings and flex discs are available, the problem is the pinned in u joint and no body has the tool to change a mercedes u joint.
I went a different route.
