Old Aug 14, 2019 | 08:23 AM
dedwards0323
Default Re: Procedure for replacing flex joint?
A lot of service shops, even the independent M-B ones, will quote the entire drive shaft assembly whenever the center support bearing or flex disc needs replacing. It's the easiest repair to make. Just happens to be the most expensive, too.
