Old Aug 14, 2019 | 08:30 AM
ala_xfire
Default Re: Procedure for replacing flex joint?
A lot of service shops, even the independent M-B ones, will quote the entire drive shaft assembly whenever the center support bearing or flex disc needs replacing. It's the easiest repair to make. Just happens to be the most expensive, too.
Also covers them if they were wrong and the center support bearing was not the problem, plus they make more on the traditional markup for a more expensive part.
