Old Aug 14, 2019 | 08:32 AM
RL67037's Avatar
RL67037
Default Re: Starter wont engage.
You have had the RCM out so you know how to do that, take it out and remove the case and see what relays work when you turn the key. Somewhere on here DJ says what relays should close. Maybe the ECM relay is getting no power.
I haven't given up yet - I just lost my helper for a while (she's a teacher and has been spending more time at school than at home). Once our schedules re-align, I'll do this and report my findings.
Originally Posted by lovecross
I'm just a fly on the wall here...but, imho...@ 6 years old, it is Time for a new battery, charged before install, (if rcm is good). For the past 3 years, ours was not driven much either. Whenever she sits for more than a week, I put an automatic 3 amp charger on and leave it on till the next time on the road. (Using Napa #8448, maintenance free, conventional, "legend" battery.) Small price to pay for periodic maintenance.
A new battery is definitely on the list of things to do, but I don't want to spend the money on that right now when I haven't proven what is causing this. I would think that with the battery still providing 12+ volts, along with the assistance of the battery charger, that this set up would overcome a weak battery. What is really throwing me is the battery will engage the starter when jumping it to pin 6 of C106 but won't when going through the full starting circuit - that tells me the battery is strong enough to at least trouble shoot with. Also, the "blip" of 12VDC on that pin 6 of C106 and then going to nothing I think is the problem. That (to me) is something in the logic of that starting circuit that isn't holding 12 volts on that pin for a few seconds. And, the RCM has been redone by DJ and given a clean bill of health, but I'll still check the relays to make sure they are doing what they are supposed to do.
Thanks again for all the ideas and comments - much appreciated!!
Randy
