garys383
thx for all the help but still no crank. lights seat windows etc work, battery checked and is good replaced the rcm today and still nothing. so now im stumped if anyone has any ideas id love to hear them. I have no crank no nothing under the hood like it wants to start. thx again
I'm having the same problem and am discussing it in a different thread. I still need to have the battery checked but if that checks OK I'll be in the same boat as you. That said, I'd like to see if I am getting the same voltage checks as you.
In the front of the same box as the RCM is connector C106. That connector has a wire in it that comes from the pulse module and energizes the starter - it is in position 6 of C106 (there are a total of 8 positions in this connector but only 6 are used). The "socket" side of that connector goes to the starter (Engine Side) and the "pin" side comes from the pulse module (Engine Compartment Side). You can take a piece of 14GA wire and make a jumper (I used 12GA ROMEX) and jump from "socket" #6 to the positive post on the battery and your starter should engage - that will prove your starter is good.
Then, with a DVM, read the voltage on "pin" #6 when the key is turned to the start position - it should be 12+ volts and should hold that voltage for a few seconds. Mine only has voltage for about a half of a second. Can you check your voltage there and see what you are getting?
