Old Aug 15, 2019 | 10:02 PM
amx1397
Default Re: Procedure for replacing flex joint?
Date: Wed, 14 Aug 2019 18:06:20 -0400
Subject: Re: Reply to thread 'Procedure for replacing flex joint?'
from Needswings U will get the correct parts ,,,
example e bay and parts store,, most flex disk the steel inserts are too big,, yes you can pull them in with a wrench but U may not get them apart later ,,,they are not interference fit.. when u remove the driveshaft look at where it slips joins one half of the driveshaft has 2 bumps and the other 1/2 has one bump this is the balance alignment ,( it is like take your left hand ,hold out 2 fingers and take your right hand and put your one finger between the two this is when you reassemble the driveshaft. jim
i though i posted this but 3 of my post have come back undelivered
