Old Aug 22, 2019 | 04:05 PM
onehundred80
Default Re: How to remove the front headlight assembly
Originally Posted by Johnny Versatile
Thanks folks. Kept digging and I found a thread about using the open end of a crescent wrench, I used 5/16 and slip it thru from the top on to the socket. Remember "lefty loosy and righty tighty". 1/4 turn and the socket will come out, pop out the bulb and reverse the procedure. You can use a finger to hold it in and the with your wrench on the fitting you can slowly turn it. If difficult to turn,slip the end of a screw driver through the box end of the wrench and use leverage for a turning motion. Ten minutes per side when you know what to do. I put in LED's. VANSSI T10 194 LED Light Bulbs 6000K White 168 2825 W5W 9SMD 2835 Chipset LED Replacement Bulbs for Car Interior Dome Map Door Courtesy License Plate
Good info for addition to Butuglys original posy from eight years ago. CLICK
