Old Aug 27, 2019 | 07:55 PM
James1549
Default Re: Sceem module
I dont think lawyers are the answer here.
I like this gentlemen's approach:
https://www.crossfireforum.org/forum...reem-unit.html
Your SKREEM is NOT certain to go bad. You can lower the odds of ANY module failing by following these recommendations:
1) Do not jump start another vehicle with your Crossfire.
2) Only jump start your Crossfire with a booster battery - NOT another vehicle, tow truck or plug-in booster.
3) Keep battery posts, ground cable connections clean and TIGHT.
4) At four years, replace the battery.
5) Perform one of the two mods in this thread:
https://www.crossfireforum.org/forum...le-engine.html
6) If your car is a convertible, NEVER put the top up or down without the engine running.
I've had three Roadsters over ten years and 110,000 miles; never had a SKREEM failure.
(7) Always have a battery tender connected when not driving your car for extended periods.
