Old Aug 28, 2019 | 01:24 PM
onehundred80
Default Re: ABS system and break bleeding
This is a question for the electronic geniuses we have on the forum.
When the ABS is used what kind of signal does the unit get from the sensors? I was thinking of buying a spare ABS unit and seeing if I could trigger it to actuate the solenoids inside it so they pumped out the air in the ABS unit on the car. The connector to the ABS unit has a lot of pins on it and finding the correct pins may be a bit of a headache.
Obviously, the idea is to replicate the dealers DRBIII units function to bleed the ABS module.
Can it be done?
