Old Aug 30, 2019 | 12:15 PM
onehundred80
Default Re: DRB III Emulator?
Originally Posted by John&Terry
You will need this:
1) Good computer knowledge
2) A laptop with a clean Windows XP or Windows 7 installation on it. Nothing else. Networking and Updating turned off.
3) A Micropod 2 Clone V17.04.27 wiTech MicroPod 2 for Chrysler Diagnosis & Programming Tool Multi-language
4) Follow these instructions How to install DRBIII Emulator for Micropod 2 on Windows 7 Pro 32-bit | OBDII365.com Official Blog
5) A TPMS tool to "chirp" the sensors so the vehicle can read them (I use the Autel TS601)
6) Perform a TPMS Relearn sequence using DRB III Emulator. Chirp each wheel when requested by the emulator. (Takes about 5 minutes)
I read the instructions and ended up more and more confused as I read.☹️
I have found nowhere an explanation of what it can do, I assume it can cancel error codes but what else?
Do you know if this can bleed the ABS unit, thanks in advance for any reply.
