Old Aug 31, 2019 | 03:05 PM
John&Terry's Avatar
John&Terry
Default Re: DRB III Emulator?
It mentions Bleed brakes on page 90 of 140, does that work and does it include the ABS bleed?
Somewhere in the write-ups, it says that Win 7 Professional works and XP does not, maybe it was Rudy who said it.
Thanks again for any help on this problem.
Unfortunately, I can not find any option to bleed the brakes in the ABS section of the DRB III emulator.
Page 90 references the ABS (Section 11) in the DRB III Manual, page 11.2. I ran the emulator on my 2005 SRT6 Coupe today and tested the ABS function. Attached is a printout of all the ABS functions and the options for testing and diagnostics under each of those functions. Unfortunately, I did not find any option to bleed the brakes. Page 90 of the manual indicates Brake Bleeding is located in the ABS Section under Miscellaneous Functions. However, when running the emulator in Crossfire mode only the following options are listed under Miscellaneous Functions: 1) Erase Zero PT-Offset Error, 2) Relearn Steering Angle.
[img]file:///C:\Users\John\AppData\Local\Temp\msohtmlclip1\01\c lip_image002.jpg[/img]
Using DRB III Emulator with Chrysler Crossfire Options available under ABS - Miscellaneous Functions
File Type: pdf
