Thread: Battery Drain
Old Aug 31, 2019 | 09:09 PM
GraphiteGhost
Default Re: Battery Drain
The box you refer to is (I assume, correct me if I am wrong) the small cigarette box with the three fuses in it:
200Amp - entire harness of the car except the feed to the alternator, brake pump and engine cooling fan
50Amp - Brake pump
50Amp - Engine cooling fan
The other battery positive cable goes to the starter and then on to the alternator. So, essentially, the entire car's electrical system is fed thru that box, AND, other than cooling fan, brake pump and alternator, the entire car is fed from the 200 amp fuse. Since almost ALL current flowing ("parasitic drain" or otherwise) flows thru that 200 amp fuse, of COURSE you will measure current going to it.
It is easy to pop the cover off, do so, you will see that there are only three fuses in there. The only way current can "leak to ground" in there is thru the plastic body of the box itself.
But since I like watching people learn, I encourage EVERYONE with a battery drain issue to replace that box. Do it first, then report back to this forum with your results.
Ya right, you just have to be kidding..... Hahahahahahahaaa
