onehundred80
It would be helpful if you told us when this happened, did it just come out of the blue or did you do something.
I have never heard of this issue on the Crossfire. If the radio had been changed or messed with in some manner the constant on power may have been switched in place of the switched power.
The OEM radio can be turned ON with the ignition OFF. It will switch OFF after a set time or when it senses the battery is getting too weak.
Case NumberK21807142
Vehicle IssueRadio will turn on with out the key in the ignition.;Base or navigation radio.
System or ComponentAbnormal Behavior / Function;Customer Concern (No DTCs);Radio;Ignition Turned Off
RecommendationIt is normal for the Crossfire radio to play without the key in the ignition.
Modification Date02/27/08 3:18 PM
correct but i think if i recall you can turn it back off and it will start to behave normally again. i remember coming across this exact issue once but i can't remember if i ever found a issue.
