Old Sep 16, 2019 | 12:35 PM
droopaloop's Avatar
droopaloop
Default Engine lost power
Driving on a two lane road, I went to pass a car. Down shifted to fourth and floored it. While passing the crossfire losses power and has a bad vibration from the engine when the accelerator is pressed, it kind of felt like one side of the engine wasn't firing. I pulled off the road and when it got to idle speed it shut off. I checked the engine to see if there were any obvious breaks and/or loose connections. I didnt see anything and went to restart it. It fired back up normally and i was able to drive it just fine afterwards. Kind of thinking coil packs have a bad connection or they are going bad themselves. Any thoughts?
Codes pulled after : p0128, p0410, p0406, p0174, p0171.
Also i changed gears and the vibration happened in 2nd and 3rd gears so it is unlikely it is clutch or transmission related.
