onehundred80
Chrysler adopted the Mercedes auto gearbox, it is probably in the Charger and so shares the basic design with the Crossfire.
My auto shifts up and down quite freely, it is self monitoring if you try to change at too high or low revs though.
I don't manually shift mine much, I let the auto be an auto. I have on occasion went ahead and manually shifted mine but didn't like it. Guess one has to do it a lot to get the best feel for the conditions? Also, I believe if you over-torque or over-rev, it protects itself as best the program allows. I doubt the handling, weight shift, suspension, program, and if the NAG1 is in both, if so I doubt it is programmed the same. I suggest you saying 'probably is more a guess than a fact. Is there anyone here who knows for a fact? BTW, there could be a mechanical problem, a fault in the TCM, or other technical/electronic problems in his crossfire.
