phil alvirez
could any1 provide details on how to do that with a booster battery?
video?
there is this way: https://www.autosimple.com/blog/how-...-jump-starter/
does any1 think this is the way to do it? any objection?
or it has some flaws and better do it other way? if so, which way?
thanks
You're asking the right question. Boosters have the large alligator style clamps like regular jumper cables.
There is a safe way to connect to your battery but I think the biggest part of that safety is minimizing the creation of a spark around the gas produced by a charging battery. Having said that; you should connect to the positive post of your battery first and a good grounded place on your chassis or engine last. You can connect to the negative battery post (like I do) but the recommendation is the former method.
Note: Your booster probably has an on/off switch. You should have the booster off before connecting. My booster has a tag that gives the correct procedure. If you do a quick internet search on "safe battery boosting" you can verify and be safe. Hope this helps..
