phil alvirez
i interpret what you say, or are trying to say, as this:
1- " A plug-in booster is a module that plugs into the 120 Volt electrical outlet and produces a high current 12 to 14 Volt supply to bolster a weak battery."
(produces a high current, but not too high)
2-then: "They can produce overvoltage spikes that can (and will) damage the electrical & electronic systems in post-2000 autos. The other recommendations won't. "
(i think that when you say "they", you mean: "the other cars batteries", right?)
No, I was commenting specifically on the plug-in boosters.
The other cars' batteries are not the culprit - they cannot produce voltage spikes; but the other cars'
electrical systems can & will produce voltage spikes that are potentially damaging to other cars.
To sum it up, voltage spikes are the bad guys; and voltage spikes
may result in excessive currents in your electronic modules.
