twanger
Driving my 06 coupe home after purchase I could hear a very slight whine coming from the rear so following the manuals mention I changed the differential lube which was black @.47k . I used Mobil 1 synthetic 75 - 90 & now cannot detect the whine . I found a short grade 5 bolt of the matching plug hex & welded a matching nut on the end to remove the plugs which req'd a breaker bar to loosen . Both plugs are the same hex.
I've done every problem preventative thing I could from this site & some of my own --- re-soldered the relay 3 joints which were cracked , added a neg cable from batt to bell housing which seems to have added a little pizazz to charging of the new battery when driving as it cranks faster when starting ?? Replaced the cam & crank sensors & better insulated the crank sensor from heat .
To avoid lisc plt holes in the vertical front bumper face , I made some L brackets that fasten unseen to the horizontal bumper surface below the face w/ screws & double sided VHB tape .
Also made some adaptors out of 20" pieces of 2 x 10's to enable using my existing car ramps w/ the Crossfire .
I really like this little car which has had no problems prior to purchase that I'm aware of as the previous owner took very good care of it . Street rods are nice as well as the 01 Carrera we had , but for the price , this Crossfire is a fine little head turner to be enjoyed hopefully for some long trips .
We've had our 2004 and only started really using it since we both retired. I did the solder thing on the coils several years ago, they lasted a long time but I lost a coil recently and bought a new one for around $100.00 on Amazon. Just did the battery replacement on the alarm system under the wipers. Just did the sticky key fix (almost got stuck) yesterday, took a few hours, wasn't bad at all thanks to a great write up with pics posted here. I looked at the clock and it only has 42K on it so we plan on running this car till the wheels fall off. All cars have their quirks but, thanks to forums like this it sure makes it easier to do a repair then ever before......Happy motoring!
