Re: Beeping above 75 mph
I created a new thread late last month. Just do a search on Foxwell and you will find it. I was surprised with the information it provided in a couple areas, but overall I cannot recommend the scanner. Some functions were just dead ends, and it did not do all that was outlined in the website worksheet list. If someone had a convertible top problem it can provide detail information. I decided the value was not there to do a full test and detailed document on the scanner with other projects I have going on. I would check for a specific scanner function if requested. One function important to many is the tire pressure reset procedure. I tested that function on my 06 coupe and it did not work. Nothing wrong with the sensors as the reset worked using the DRBIII. It may work with 07-08 Crossfires as they have some scanner communication differences, but my 07 does not have tire pressure sensors to test.
