Old Oct 13, 2019 | 11:37 AM
onehundred80
Default Re: sensors-lets learn about
Testing of these sensors is outlined in the Service Manual. Read it, maybe there is a clue there.
The crank sensor is thought to fail sometimes due to corrosion causing a bad connection at the connector.
The camshaft sensor seldom fails so it is not worth worrying about.
Instead of adding two posts separated by minutes, use the EDIT function to add to your first post, simple, effective and neater.
