Thread: which scanner?
Old Oct 14, 2019 | 12:21 PM
g wheels's Avatar
g wheels
Default Re: which scanner?
Originally Posted by phil alvirez
am getting the scanner, but 1st have to learn all about it-that i hope the manual will help. am hearing that is crucial to learn what and how to play with it because doing some things or a certain way may damage something into the car. dont know what but it seems possible. will not do anything before asking here and anywhere. just in case.
Phil, inexpensive scanners will do no more damage than resetting fuel/air trims to default which could make a deteriorating engine initially idle rough or be difficult to start. I do know of one instance where a poorly running engine would not start after a battery replacement which is the equivalent of clearing the DTCs that scanners can do. A "scanning/programming tool" is another animal. There are scanner / programmer tools but they tend to be expensive. Of the half dozen pcm tools that I own two of them will do programming and they are for my camaros. Again, the ones that can reprogram are what I consider expensive ie the DRBIII for our crossfires.
