Old Oct 23, 2019 | 12:04 AM
  #318 (permalink)
onehundred80
Default Re: Valve cover leak...
Do a site research about the leaking valve covers, lots to read, you'll see it is a little different from general valve cover leaks. It uses a certain goop stuff that must be applied IAW (in accordance with) a specific way or leak will reappear. Also, the posts give certain warnings about tightening/replacing the low torque bolts (the valve covers are a softer material as well).
I do not see why this cannot be used, it is sensor safe and basically the same material. The poster has experience with it as well.
