InTheMidst
Well, my mechanic knows Benz parts and found a new one. Says it is all working like it should. So, I'm heading over to pick up my Crossfire. Will ask about "look for signs of water in the lower rear hatch bay after you remove the trim and Styrofoam and unwrap the air pump module that opens/locks doors/hatch/and flashes lights. Water in there screws many things and gives ppl headaches".
Will update.
Thanks
You do not have to strip the trunk looking for water, just fold up a piece of newspaper so it is strong enough to push down the front edge of the foam block in the well. It will be obvious if there is water in the well. The front edge is the deepest part of the well.
I think the price is a bit too much a siren that beeps is $150 or so, with at most an hour to pull the cowl and replace it, so I would say it is about $80 too much at least
Remember you want a beeping siren and not the half-price silent one.
