88stevie
Hi guys,
I've done a bit of digging and I cannot for the life of my find a solution. US Crossfire here, 2004. Everything was OK then it just stopped.
Here's a problem:
- My key fob/remote will not lock/unlock the car.
- My key when turned in the drivers side lock only unlocks the drivers side door.
- The lock/unlock on the console works.
- When I put the key in the ignition and turn it to ON and then press the buttons on the key, the doors (and trunk) lock and unlock. Only reason I now this is because I tried to reset my key.
- As normal, lights flash when remote is pressed.
- Interior lights do not work despite changing the fuses. They won't even turn on manually!
What I've done and it's not solved my problem:
- Changed the batteries in the remote
- Attempted multiple times to reprogramme the remote
- Changed fuses under the hood.
What I've not tried yet:
- Not changed the square relay/fuse under the hood.
Anyone have anymore ideas?
