Old Nov 7, 2019 | 04:00 PM
maggy55's Avatar
maggy55
Default Re: New SKREEM, Locks and 2 Key Fobs Available
SENTRY KEY VERIFICATION TEST
1.
Turn the ignition off.
Disconnect all jumper wires and reconnect all previously disconnected components and connectors.
Note: If the SKREEM or the PCM was replaced, refer to the service information for proper programming
procedures.
With the DRB III, erase all Diagnostic Trouble Codes (DTCs) from ALL modules. Operate all functions of the system
that caused the original complaint.
Perform 5 ignition key cycles leaving the key on for at least 90 seconds per cycle.
Turn the ignition off and wait 5 seconds. Turn the ignition on and using the DRB III, read DTCs from ALL modules.
Are any DTCs present or is the original complaint still present?
