Old Nov 19, 2019 | 08:36 AM
KeithTexas's Avatar
KeithTexas
Default Re: BCM clicking window won't go up
Originally Posted by Mommasride
Nice always wanted to try that. Thanks a lot of good info there. I got a used replacement BCM on the way so well see. Also thinking about a work around switch for the window.
Sounds good. Please post a follow-up on the success you have with the BCM. The only other thing that I've found...and you've probably already seen it in the Service Manual:
"If the Body Control Module was replaced, turn the ignition on for 15 seconds (to allow the new BCM to learn VIN) or engine may not start."
You also may have to go through the reprogramming steps for the key fob in order for it to unlock/lock the doors....
