Old Nov 19, 2019 | 12:22 PM
  #343 (permalink)
phil alvirez's Avatar
phil alvirez
Default re: SKREEM Repair Infomation
Originally Posted by ZERACER
I have read about SOS, in the past, but have never seen a posting from someone that has used them. In wolfstalkers credit he has actually let everyone know MDP was successful. I would love to hear from someone that had had success with SOS on their screem or key replacement.
once i contacted rholstrom and got the following:
Quote (Originally by phil alvirez)---
once you posted this: "If you are having SKREEM problems I suggest using "SOS diagnostics" near Portland Oregon. Look them up online. I diagnosed a no start problem with the help of this forum to be the SKREEM. I had the SKREEM & ECM removed and sent them along with our only key to have repaired by SOS and have 2 more keys cut and programmed to the system. We saved over $2500 for what the dealer wanted to do and got 2 new keys in the process.
S.O.S. Diagnostics (S.O.S. Diagnostics) "
i asked: could you tell how is it going? i have not seen any other post telling that sos has done this for them.
thanks
---End Quote---
his answer:
"The keys still work to start the car without any problem. The dealer at the time wanted to replace SKREEM + ECM + get new key made for $5000+. I think the price SOS charged was about $1800 to, diagnose the SKREEM, fix the SKREEM, reprogram the ECM and have 2 new keys made. The sealer charged $480 (4 hours labor) to have the SKREEM & ECM taken out and them put back in after SOS was done. "
but still it does not explain what exactly was done. and the amount is way higher. that is the only 1 i have succeeded in learning about what SOS has done.
