Old Nov 26, 2019 | 02:24 AM
GraphiteGhost
Default Re: Oil level sensor
Originally Posted by Mtnears
Just want to make sure I'm doing everything right and hopefully understand exactly what I need to fix :-)
2014 CF. Oil level light comes on and stays on when starting for about 10 minutes or so.
First, you do not have a 2014 Crossfire! Second, errors in the oil level have been linked to TOO MUCH OIL in the engine. I would suggest not filling the oil to the max level on the dipstick (if even slightly off level will read too high triggering the sensors). The absolute oil level test is the OEM dipstick on level ground. There is history of a level sensor being 'stuck' or defective (some say due to chronic overfilling allowing the sensor to eventually stick). There are .pdf documents here in the forum to replace a defective sensor (if it is stuck). Good luck!
