Old Dec 1, 2019 | 06:04 PM
GraphiteGhost
Default Re: Show of hands... N/A EuroCharged Tune??
Originally Posted by ZERACER
It does eliminate the lag caused by fly by wire..
In my professional opinion, it (sprint booster) only increases the action (span) of the OEM pedal assembly to throttle body action. If you want to call that eliminating a 'fly-by-wire' lag(?) then that's what you believe. If you increase a response to a pedal push I guess you could think it is eliminating 'some' lag BUT it is just being acted on sooner because of the faster 0 to 100% pedal/throttle body travel response.
In my opinion, it is a lot of $ to have the result of a pedal that only has to be pushed 1/2 the way down instead of all the way down for throttle body full opening (disclaimer, the span of pedal vs TB response is not 1/2 pedal travel to full throttle body opening). That is the way it works, not the actual measured travel of either. Just the same, it is what it is doing electronically.
