GraphiteGhost
Check my signature, all my mods are there. The sprint booster (to me a waste of $) just make the car believe your pushing the pedal further than you are. Its like taking half (my words) the distance of the pedal for full pedal travel. In my opinion, it does nothing except make the pedal travel much shorter. I consider it if you press the pedal 1 inch its like pressing it 2-3 inches (press it 2 inches its like 4-5 inches response). That's all in a nutshell.
Of course, you drive an Automatic.Push and go. push harder go more faster right?? But for those of us with 6 spd trannys, the Sprint booster it is a MUST!!! Throttle response is critical, especially if you double clutch the down shifts. The "lag' is time wasted when you need to be shifting quick.
Going from 6th to 5th is easy but going from 6th to third is virtually impossible without double clutching. If you engine brake you need that capability.
As for the Eurocharged tune, I highly recommend them. But not without some other mods to exhaust systems and a good CAI. Get the air through the engine.
The unit form Needswings is highly recommended.
Some will argue the actual numbers but 265 HP vrs 215 HP from the factory, is significant.
