Old Dec 9, 2019 | 12:27 PM
Speedy4x4's Avatar
Speedy4x4
Default Front / rear coil spring specs and info.
I am looking to change out my coil springs all the way around. There several aftermarket lowering options, but I want the stock height.
I was pulling the front tires off last weekend and checking the brakes, and had a o crap moment, both of my front coil springs are broke
I have a set of airlift 1000 in the rear coils, giving me some more strength.
Debating on changing out with srt coils, which have around 100 lbs per inch additional rating (will post the specs I found later) and putting my bags back in the springs, might only keep 5 lbs in them.
Leaving the rear and just getting a pair of used fronts, but with more and more broken coil threads, I don't want to have to wonder if it will happen again.
Not looking for lowering since it is my dd, stock height is fine.
or if I go air, then there is height options, 4" convulated bags or 3.5" sleeve bags.
Thinking about coil overs also.
Anyone changed their coils out to other than oem springs?
and not lowered?
Need to get full specs and look at more options, and see what vendors have what springs rates available.
cutting and grinding down coils is easy, the hard part is finding the right lbs per inch.
But you know me, when I change something out, I have to be different lol .
