Re: U-joint replaced around $100.00
good job,, thanks for the pic. your washers are the perfect spacers to center the u joint . i see you used one spot weld on one side and two spot welds on the other . did you reblance the shaft. ? if i had seen one weld on each cap i would not have ask that question,,,and that question was ask because of the speed on the track that i do in my car.
