Old Dec 18, 2019 | 01:39 PM
Rocafellafw11's Avatar
Rocafellafw11
Default Re: No start, no crank, full power, good fob
Originally Posted by 1stknight1
Hello Wolfstalker!
what was final resolution on your nonstart? Had similar challenge last Friday and not w vehgicle sitting!
No resolution yet. Using this diagram I have concluded that:
A: The pulse module is not sending the starter a signal
B. The pulse module is not receiving a signal from the clutch interlock switch
C. The Clutch Interlock Switch IS sending out BOTH a ignition signal AND the clutch switch signal. Somehow between the Pulse Module and Clutch interlock system there is a break in power. Ran out of time for today and need to head to work. I will keep this thread updated.
