dedwards0323
The Autel TS501 Scanner arrived yesterday, which was the last piece of hardware I needed to proceed with setting up to clear the TPMS fault. I'll start the upload of software today & see if I can clear that light.
Sounds like you have everything you need. If the laptop has audio, you will hear a beep after each wheel's ID is accepted by the TPMS system. Four beeps and you are done. On screen instructions will guide you through the process. Good Luck!
