Old Dec 31, 2019 | 06:27 PM
  #42 (permalink)
John&Terry's Avatar
John&Terry
Default Re: DRB III Emulator?
So I've loaded the software & the Autel TS501 TPMS scanner works fine, recognizing all the sensors, both OEM & new. But I don't see how I get the new wheel sensor IDs into the TPM Module using the DRB3 Emulator. I'm missing a step somewhere. Could use a little help.
You are actually going to perform a TPMS relearn sequence using the DRB lll emulator. The individual wheel sensor ID's will be read by the emulator and automatically programmed into the TPMS. I am away from my home right now. But I will be happy to run my emulator when I return home and let you know exactly what process to follow.
