I got at things this afternoon. Used degreasing agent on the diffusers. Then shot a light primer coat and then a heavier primer coat from a rattle can. After a couple hours I sanded it with 600 wet until all the micro ***** were gone/ blended as smooth as glass. I want it as good as the body. Will degrease again after supper and then shoot another primer coat to cover everything evenly. When dry, I will sand with 1000 wet. Probably shoot the yellow tomorrow using my airbrush.You will note the white burn thru. It appears that the black finish is the gel coat that the molds were sprayed with before layup. They are really well made.
Ready for another even primer coats
