Old Jan 4, 2020 | 10:54 AM
lotsofspareparts's Avatar
lotsofspareparts
Default Re: Frozen ignition switch, need to get out of Park
Originally Posted by ZERACER
What do you mean, the ignition is stuck? If you can not move the shifter, the manual tells you how to but a screwdriver in and release it. If the steering lock is stuck, you must do the sticky inbition fix described on this site.
I get that the sticky ignition repair will need to be done..... already planned on it. I can't do any repairs on the vehicle in it's current location though.
I just have to get it out of park so that it can be winched onto a trailer, then I can work on it here at home.
If I am understanding you correctly, I can disable the shifter lock with the ignition in the off position? I will go through the manual and see what I find.
Thanks, Jared
