Re: I need help fixing rear rotors with locked up calipers
1. did you look at my post, “Rear ventilated 300mm disk”, 2. in your photo it looks like one of the pads is in backwards? Also are those AMG calipers with a sensor? The SRT and NA do not have rear wear sensors, the #1 photo on my rear 300mm upgrade for a NA shows the caliper you need. If you got the SLK 3.2 AMG rear calipers I do not know if they will go on the Crossfires.
what year and type car are you doing this on? Even tight pads will not score a disk like that.
