I need help fixing rear rotors with locked up calipers
Old Jan 23, 2020 | 07:03 PM
psuperti's Avatar
Default I need help fixing rear rotors with locked up calipers
I need help I let a total stranger who self proclaimed to be a certified mechanic do the rear amg c32 upgrade. What would cause the calipers to grab the rotors so tight and never release? The actual caliper is against the rotors metal to metal with the pads now damaged as I see little shards of metal. I Drove 3 feet before noticing this.
During the installation my 1st observation while i was installing the new wing, i noticed he let the fluid level drop to the bottom of the reservoir. 2nd no bolt on the rotors to hold it in place. 3rd he was trying to get the pads to give him more space for the rotors with a metal tip of a screwdriver driver.
I left for 30 min to get more bottles of Motul 600 I come back the car is not drivable. I attempted to bleed the brakes alone and lost light quickly and had to stop.
Thx
Rotor
This is the caliper c32 AMG rear
Old Jan 23, 2020 | 07:38 PM
Default Re: I need help fixing rear rotors with locked up calipers
Wow, looks like some wrong combination of parts. Good luck figuring that out.
Old Jan 23, 2020 | 08:39 PM
Thx
Rotor
What size rotor are you using, thickness and diameter? Spacers?
Do they fit the NA as well as the SRT.
NA rotors are smaller than the SRT rotors, so maybe the bolt holes for the calipers are closer to the axis of the rotor.
The caliper looks too close to the hub and causes it to rub, the offset appears to be incorrect.
Old Jan 23, 2020 | 09:01 PM
DHS's Avatar
DHS
1. did you look at my post, “Rear ventilated 300mm disk”, 2. in your photo it looks like one of the pads is in backwards? Also are those AMG calipers with a sensor? The SRT and NA do not have rear wear sensors, the #1 photo on my rear 300mm upgrade for a NA shows the caliper you need. If you got the SLK 3.2 AMG rear calipers I do not know if they will go on the Crossfires.
what year and type car are you doing this on? Even tight pads will not score a disk like that.
Old Jan 24, 2020 | 07:33 AM
psuperti's Avatar
This is the 04 limited. I had to use longer bolts then the 10 mm.
I'm using 02 c32 AMG rotor (300) and caliper, my everyday 10mm spacer
I have read and kept screen shots from the c32 brake upgrade threads. Not too much info on rears. It said they bolt on, it said use the 300mm rotor, it said get 12 mm bolts. It said the black wire is not used on the regular xfire.
I'm dismounting the calipers this am. I have one more set of pads if the problem is fixable. I puchased grease for the pins in case the pads were not sliding on the pins. I can switch every part back the way it was if necessary.
This is the caliper I'm using
Old Jan 24, 2020 | 07:39 AM
psuperti's Avatar
This is the Zimmerman rotors from auto zone its vented
Old Jan 24, 2020 | 08:06 AM
psuperti's Avatar
DHS yes, I read your thread thx
Maybe the bolts are to tight
Old Jan 24, 2020 | 10:53 AM
It looks like the calliper is too close to the rotor spacer are probably required, the photo shows the pad right inside the calliper, if the pad on the other side is well out of the calliper surely a spacer of the correct thickness to equal the pads out.
Maybe it the wrong combination of parts.
Old Jan 24, 2020 | 12:01 PM
psuperti's Avatar
It looks like the new rotor is not sitting straight. Something about the e brake being in the way. I tried to streghting it out and have to admit that it's super hard at the moment. I have released the e brake. Should I pull it again and take the car of parking gear instead (and see if it helps)? Its an automatic xfire. Here's pic:
Old Jan 24, 2020 | 12:55 PM
Speedy4x4's Avatar
Looking through the lug holes, does it look like the rotor is seated all the way?
If not I would pull it off and inspect parking brake and adjustment.
Old Jan 24, 2020 | 01:40 PM
psuperti's Avatar
It's not I'm sanding the exterior of the e -brake to try and solve it. I'm going to put on the used pads since the wear on it is going to give me some room. I think this e- is moving and in the way. Picture:
The outer dust cover in the way or e-brake?
Old Jan 24, 2020 | 08:36 PM
psuperti's Avatar
Did anyone else need to cut the bottom of the dust shield? Or just me
Old Jan 25, 2020 | 01:57 PM
psuperti's Avatar
Is it a big deal if I remove the caliper dust shield? My neighbors are sick of my noise
Old Jan 26, 2020 | 08:29 AM
Speedy4x4's Avatar
By the wear it looks like something was not right, hard to tell the exact problem without having eyes and hands on.
measure the inside drum diameter on the new rotor and the old rotor, to see if the new rotor is ismaller.
If looks good, adjust the parking brake mostly in so that can be ruled out, set the rotor back on and see how it fits, if good red adjust the parking brake, if that is ruled out have to look where it is hitting at.
by the marks it looks like the diameter is to small, but could have been wedged on by the parking brake.
Old Jan 31, 2020 | 09:15 PM
psuperti's Avatar
Upgrade complete. I had to cut the dust cover area by only the layer next to the e- brake the rotor had a lip that I had to make space for.
Old Jan 31, 2020 | 10:17 PM
There is a post somewhere that mentions and I believe has a photo of the cut dust shield.
RogerO
Jun 25, 2021 01:51 AM
JHM2K
Apr 2, 2014 05:01 PM
04Fire
16
May 9, 2010 12:58 PM
JimmySkullz
Nov 5, 2009 12:41 PM
Sidez
Dec 16, 2007 07:05 PM
