Old Jan 25, 2020 | 08:06 PM
GraphiteGhost
Default Re: 2005 car start issue
Originally Posted by Brian P
2) Is it possible to add the mod so the horn beeps when you lock/unlock the car?
Thanks,
- Brian
As far as I know, no one set up a horn beeping when the car is locked or unlocked. The beep that the siren does is a 'chirp' that is built in to the newer sirens. You can put a 'chirping speaker' in the under hood fuse box, wired to a relay already there. Searching chirping in the forum, that might find the posts. Good luck!
