Old Jan 26, 2020 | 05:40 AM
GraphiteGhost
Default Re: Modifying thread content
Originally Posted by IB JT
For disclosure, it may not be a speedy fix that you may be wanting. It's nothing to do with Crossfire as this bug has been identified as occurring with all other sites in the network using the same editor (i.e., many sites). There is no new update since my previous reply. The issue is known and still being reviewed as to how to address. Since this is considered a bug, and it's isolated to specific usage of the size tag which is limited in usage, it will likely take some time. That it also involves a feature that is not exactly fully supported (which is why the option hasn't been on the toolbar for a while) as it doesn't scale well across multiple platforms, and is also part of a complex editor, doesn't help.
To note, you can still edit posts and signatures and still use the size tag. All that's happening is the What You See IS What You Get editor is not parsing the size tag properly in the preview mode. The tags and content are still there but are "hidden" in the preview due to the bug. You can edit around it and/or use the source button if you have some familiarity with HTML. Yes, it's not easy to update, but it's possible and not actually rejecting any content.
Thanks JT, I guess I'll have to find another 'work-around' to this. I'll start trying to 'modify' my signature and see just how much I will have to slice off again so that the updates can occur. That was the only way I (in my limited understanding of the issue) could get the signature updated. Maybe I'll just eliminate the miles/date line in its entirety, that SHOULD give me back a number of character spaces (that's how I was able to 'fix' this the first time this happened way back @ Mar/May 2019, something about the total character #'s being reduced due to the 'fancy' sizes and colors of the sig lines adding up to over the 1000 characters allowed).
