pizzaguy
How did you arrive at the conclusion that there are a limited number of starts in the system? This contradicts what is in the student manual.
I find it hard to believe that a manufacturer designed a car with only a certain number of starts.
My module works that way, that it extract valid codes from the skreem and double them with a trick. To test my module I have extrakt about 7900 codes from my test skreem befor it is blocked. After reprogramming it to the state the skreem was before I extrakt the codes the skreem works again. I can extract the same amount of codes before it is blocked again.
I have reproduced this three times, so I'm sure that the skreem can only provide a finite amount of codes, if this is because they have only two bytes for the counter variable of the rolling code system or why the only have a 8 byte code, I don't know.
