Old Feb 5, 2020 | 06:20 PM
  #40 (permalink)
pizzaguy
Default Re: 2004 Crossfire Electrical Issue
The fuses at the driver's end of the dash are lighting fuses only. You want the fuse box on the driver's side, under the hood.
If the starter DOES NOT engage, the SKREEM is not indicated as the issue.
Do this:
Get in car, close door.
Put key in ignition, turn to "START" - observe that the starter does not engage.
Release key so it goes back, to "ON".
Wait 30 seconds - do you hear the engine cooling fan warp to high speed? z
If so, the Fan module has powered up, but the ECM has not powered up. This is usually an easy fix.
If the engine fan does not speed up to high speed, we have more investigation to do.
