franklindm
pizzaguy,
The starter does not engage.
After reading the posts in the SKREEM section I have gathered the following items to check. 1. check for water in the lower trunk, remove the foam liner. 2. Disconnect the battery, disengage the Siren Alarm in the Cowel, remove Fuse 9 inside the driver's door fuse box and reconnect the battery. Am I correct with the location of Fuse 9?
Thank you for the additional information.
franklindm
Why not write down all the problems, do not add your opinion as to the cause of your problems.
You have explained over a number of posts what they are and frankly to me they are confusing.
You are seeing solutions and I think you have confused yourself.
Sit back and refresh us with the problems.
You mention SKREEM and the air pump in the trunk together, they have no connection at all. A car with a bad air pump will run just fine except some features will not work, like the remote door locking, lights staying on for a few seconds etc.
Do not get touchy, GG never said you were stupid. Confuse us and one by one people will not answer.
