Old Feb 9, 2020 | 08:00 AM
Bargegeek's Avatar
Bargegeek
Default Re: Worlds Cheapest V8 Swap
Incredible project. Continued good luck! A few questions:
  • Is the skreem/ecu unit you're having reprogrammed from the Crossfire or the ML55 engine?
  • Did you have to pull the tranny forward a bit to remove the engine. (Kinda looks like it from the pic.)
  • Will you need to do anything to the driveline to accommodate the extra HP, or are the Crossfire components robust enough?
  • What exactly will you need to program with the MB Star C4 Xentry, if the ECU is being re-programmed?
  • Will the swap void the warranty? (Totally kidding, obviously!!!)
Sorry for what are probably newbie questions, but I'm fascinated with this. Again, good luck, and I can't wait to see more.
