Old Feb 9, 2020 | 10:32 AM
lotsofspareparts's Avatar
lotsofspareparts
Default Re: Worlds Cheapest V8 Swap
Originally Posted by Bargegeek
Incredible project. Continued good luck! A few questions:
  • Is the skreem/ecu unit you're having reprogrammed from the Crossfire or the ML55 engine?
  • Did you have to pull the tranny forward a bit to remove the engine. (Kinda looks like it from the pic.)
  • Will you need to do anything to the driveline to accommodate the extra HP, or are the Crossfire components robust enough?
  • What exactly will you need to program with the MB Star C4 Xentry, if the ECU is being re-programmed?
  • Will the swap void the warranty? (Totally kidding, obviously!!!)
Sorry for what are probably newbie questions, but I'm fascinated with this. Again, good luck, and I can't wait to see more.
The V6 ECU is being built to handle the V8. It involves adding the missing coil and injector drivers and some other things. None of the security data is modified when this happens and the Skreem doesn't know the ECU was modified.
Believe it or not, that is the OEM location for the transmission. They do sit pretty far forward which makes it really easy to get to the bell housing bolts.
I believe the driveline is robust enough to handle the power of the V8.... it is essentially the same driveline as the SRT-6.
I do not know yet what will need to be programmed once I get the ECU back. I am having Josh handle that via TeamViewer.
Jared
