Old Feb 10, 2020 | 12:17 PM
Kolme's Avatar
Kolme
Default Re: Clarify symptoms - RCM, CPS, SKREEM
Originally Posted by a1976
Hello, I have a problem with my Crossfire. I have 2 keys to it. They did work but now none of them will start the car or open the door with remote. I took it to local specialist and he says my SKREEM is no good. It has a B1000 code. What is worse, he says, he cannot buy one. He also said that this code means that the software in the SKREEM module is corrupted and cannot be fixed. I was researching the forum and came to a conclusion that these issues are very common to Crossfire. So, I was looking for a possibility of removing the SKREEM from the car somehow. So I don't have these issues again.
Thanks
Hello,
First to confirm it's likely the skreem module itself, unhook the battery to the vehicle for a few minutes and reconnect to reset the car. Attempt to turn over the vehicle. If it attempts to start, then suddenly shuts off 3 times and then does not attempt to turnover at all, then the Skreem module very well may be to blame.
The skreem module can be removed, however the car requires it to function, to my knowledge (granted I haven't had a xfire in 5 years). When I replaced mine, the dealership had to perform the repair as it requires recoding. Needswings, an aftermarket vendor, was supplying them at one point, however I'm afraid they have supply issues according to their website. Your best bet, if it is the skreem module, is a trip to chrysler.
